themangeraaad
- Halifax, MA
Jeep runs and drives again. Clutch feels like it's releasing real close to the floor so I'm wondering if I still have an air bubble in the line... then again it goes into gear fine so maybe it's just that it has a brand new clutch in there and I'm used to the mustang with a heavy cable clutch that releases a bit higher; I do recall that the Jeep grabbed a lot sooner than the car even with an old clutch so I'm not too worried. Whatever, FIRI. I'll find out if it's going to give me trouble when I finally get out for a test drive.
Mine ran fine with one bolt but I ended up JB welding that bugger on there. Thanks for the offer on an extra bolt but I already have a few spares laying around. Regardless, my problem wasn't a missing bolt but is that I broke one of the bolts off in the bellhousing so I'm SOL until I drop the trans again and replace the entire bellhousing (probably in a few weeks).
I didnt see this responded to..
I once swapped a an engine and lost a CPS bolt, it would not start till i installed the other bolt.
If you need a bolt i think i have a few spares.
