Nope, im moneyless. And need to make sure I have enough in mah tank to make it to Thursday...went a little overboard buying xmas gifts and then realized I had $5 left for the week lulz
kieth bill travis whomever post christmas come over and show me how to bench bleed a master cyl i have till the 2nd off and plan on smashing out brakes, then onto ther search for a dd, or make this my dd for 10 days
I might be able to swing up.
Really it is pretty easy. Just take the outputs and run them back into the resi and slowly move the pushrod (I used a philips screwdriver) in and out until there are no bubbles. Takes only a few minutes.
Just push it almost all the way in, then cover the ports with your fingers and release the pressure. Once its all the way back out, let off with your fingers.
Last time I did a bench bleed, I just put my thumb on the piston and fingers on the mounting ears, filled the reservoir, held it level and rotated so that the flare ports were at the top of the cylinder, then pushed the piston in slowly a few times. Then connected it to the truck with the lines finger tight, bolted it up, and snugged the line down.
Might not be orthodox but it worked great.
add it to the list of things Anthony would make fun of me for:
