THe NAC Lots-O-BFG KO2 Thread
Not rocket science.
Just ordered the Lakewood Bellhousing.
I can't wait to shoehorn this thing in there.
I can't wait to see how much you have to cut to get it in.
I can't wait to see you do 4wd burnouts on demand...with creepies.
I'm trying to think of everything I have to do involving the drivetrain swap.
- Mockup drivetrain
- Build motor mounts
- Redo crossmember/link mounts
- Transmission mount
- NP205 side mount
- Build exhaust
- Plumb cooling system
- Radiator mount
- Redo HO wiring (pull 4.0 stuff, leave ignition/fuel/lights)
- Build driveshafts
- Engine accessory brackets
- Megasuirt/TBI setup (after break-in with carb)
- T-case shifters
This is going to be another winter/spring build frenzy :laugh:
Ugh, I can't afford new tires anytime soon.
I'm probably going to run the MTRs next season. Buy one more H2 and inner air lock/rock ring as well just so I have a correct full size spare for racing.
Funny enough, home depot didn't have any foam. I know because I went there last week and they told me they didn't.
Eh, that would be a pain to reproduce and cut out the holes. A lot easier to get a new piece. Plus its like a rubbery foam, not like most of the foam I've seen at the local hardware store, who didn't have sheets of foam that big.
Old foam/rubber that has had the shape of the openings permanently depressed into it. I put more foam on it to help seal it last weekend, but now that I don't have to have it together in a few hours to drive it again, thinking about replacing it for piece of mind.
They might not have large sheets, but you can get ~1" wide, ~1/8-1/4" thick self adhesive foam strip for sealing doors and windows there. Closed cell, flexible rubber foam, comes on like a 100 foot roll, it should be somewhere over by the paint, glue/tape, and weather sealing department.
more than an emo kid when linkin park announces their breakup
did you know if you have 38's and 3.73's with a 4.0 and automatic you can smoke the tires at 30 mph if you give it half throttle?
definately a troll post. nobody is that dumb to think someone will actually believe that
link?
please tell me this is XJ longhouse saying this.
