THe NAC Lots-O-BFG KO2 Thread
In theory, I can re-use my flywheel, clutch, and pressureplate. :D
I have to see if my father/uncle have a flywheel laying around.
Doesn't look like there's a difference between car/truck or even big/small block flywheels as long as the engines were internally balanced. Makes sense since a lot of the car guys put the magnum truck starters on their cars. (longer lifespan, more compact, higher torque)
Time to start digging through my father's part's stash :laugh:
Sounds way more interesting then Colin or Chris talking about thier dildo stuff.
I know seriously. I wasn't aware it was the "lots-o-engines-and-adapters-and-colin-trying-to-be-a-mechanical-engineer-thread."
We do have a lots-o-tech thread you know?
back to work!
Yes we do have one.
We've just been choosing to post here forcing you to read it.
:D
I didn't realize giving my opinion on something made me a mechanical engineer. Sweet. Add that to my resume.
We gave you the opportunity to introduce a new topic last week, and the thread died and had like 4 posts in it all day. :dunno:
:D
Yes we do have one.
:D
You and I are arch enemies, are we not?
Don't I have to agree in order for you to say that?
I don't consider you my arch enemy. Therefore we can't be arch enemies.
I can be YOUR arch enemy. But you're definitely not mine.
Sorry dude :(
Baller. Forgot that the 4.0 is the same as the 4.2 is the same as the 304/360/401.
Just found a scan of an old AMC factory blueprint. Looks like I'll be spending some quality time in Solidworks later today...
edit: XXXXer! The Y-coordinates are chopped off. :(
Any chance it has a drawing of the crank flange for the 4.2? I need to make a custom shaft adapter to go from that to the J609B input taper on my generator head at some point and I don't feel like measuring that crap if I don't have to.
I'm not an engine builder, but would a flywheel spacer affect engine balancing?
I would imagine that would be pretty important on something that will see 7k+ rpms.
as long as the spacer is balanced around its axis of rotation I don't see a problem :dunno: I would worry more about the thickness of the adapter plate XXXXing up how deep the input shaft of the trans goes into the pilot bushing/bearing. If there isn't enough coverage I can see the bearing wearing out faster.
Shit, I can get a smoking deal on a 4.0/AW4/NP231 combo but I'm not sure if it will all bolt together i'll have to machine some custom spacers and make custom length driveshafts and cut the floor up a bit and call Dannys BS adapters XXXX this just keeps getting harder
:D
seriously man. PS I have an ultra rare factory 4.0 to AW4 bellhousing available for sale if you end up needing it.
Stuck in NYC again. Welp... I drained the pipes, drained the toilet cistern, and poured some whiskey in my toilet bowl before I left to keep it from freezing :gee:
No it doesn't, but I have one sitting on my back porch at the moment. If it doesn't have the goofy offset hole like a 4.0 crank it'd probably be pretty easy to measure.
It's pretty boring, just some diameters, and 6 1/2-20 holes iirc. The holes are not in a symmetrical pattern though to keep the flexplate or flywheel from being mounted wrong. I don't really need their positions since I'll be using a flexplate to mark the azimuth of each hole, just the offset from center. If it's not in the blueprint don't worry about it though, I have a couple 4.0s in teh yard that I can measure when I get home.
Actually I'll probably measure it anyway as it pertains to my project as well.
The SHO motor uses 8 symmetrically spaced holes. I wonder how badly the two patterns will step on each other.
I *think* only 1 bolt hole is misaligned and the rest are on 60 degree increments, but don't quote me on that.
if so, you have:
120
180
240
300
for offsets on the 4.0 pattern, and:
90
135
180
225
270
315
for offsets on the SHO pattern.
Assuming they're at the same diameter, 0/180 line up... I bet 120 and 135 are gonna be a problem, so will 225/240, and 300/315.
How much space do you have to work with lengthwise? Any chance you could make the adapter plate thick-ish, and a crank adapter that has a SHO size flange/bolt holes/pilot on the 'male' end, and a Mopar pattern on the 'female' end? Maybe make a part with a large flange and dual 8 bolt patterns (SHO and one larger, around it) and another flange adapter that has the larger 8 bolt pattern and the Mopar pattern inside that, then bolt the two together? Not sure how I'd go about adapting patterns like that without ending up with a really thick adapter.
From a convenient picture showing an SHO flywheel with a tape measure laid across it, the bolt pattern looks to be approximately 8 on 70mm (~2.75").
I forget what the 4.0 one looks like, or if it's close to that.
If it *is* that close, then I just get the existing holes filled and machine the SHO bolt pattern into it, and use a spacer with thru-holes if I have to.
ahh, I wasn't even thinking of just filling the original pattern in. Figured you'd want that to be bolt-together with all factory parts on both sides for some reason.
I think the 4.0 one was wider than that, like closer to 4".
