THe NAC Lots-O-BFG KO2 Thread
Kieth just peep mine I think I still got the templates for me legs too and suports ain't nesscery if ya don't beat on it but a good side hit to the ends will push them inward mdxj kieth had that issue
I plan on doing two maybe three legs and they'll probably poke through the floor and when I go redo the floors again I'll weld them up solid. But for one trip to Johnny's I think it'll be fine. I have 26" clearance in the front and 27" in the rear. They're high enough I shouldn't hit anything too hard
It's the end of the world as we know it. It's the end of the world as we know it. It's the end of the world as we know it and I feel fine
thats me in the corner, thats me in the spot..... light, losing my religion
Stuff the lowers wherever you can fit.
Fit the upper wherever you can get a decent amount of frame and axle separation. Aka 5-8".
Upper should be no shorter than 75% length of the lower.
Just what I've read. My upper is longer than my lowers.
Doesn't a longer upper cause the pinion to climb, and a shorter upper cause it to dive during suspension cycling? And how important is frame separation? From what I've read, the most important thing is that the axle side has good separation in order to keep the axle from 'rolling'.
bumper n skid on
Looks like I'm going to:
Chester, VA from 03-06 Oct 2011
Aberdeen, MD from 06-10 Feb 2012
Traveling for work. Gotta take a couple classes.
You're going to be Down near me in Oct 2011 Chester is only about an hour away!
bumper n skid on
Nice Bumper!
RIP Macho Man Randy Savage
ohhhhhhhhhhhhhhhhhhhhhh nooooooooooooooooooooooooooooooooooooo!!!!!!! where is miss elizabeth?
30* fitting on the pump worked perfectly, same with the 120* on the reservoir.
Gotta run some battery cables tomorrow, hack together an exhaust, drop in the harness, and hopefully fire it up on Sunday.
I got new transportation to work thanks to kieth
