mini=man
- Neh Hampshuh
I think I'm going to be heading up there with a couple friends later in the summer. One of them has a place right near the mountain and we've both wanted to ride that area. It's such a long ride to get up there... He was thinking of trailering it but I'm not sure what I'd do.
Agreed, always good to get out. I probably put 50 miles on it this weekend but don't want to do much more than that since the oil is 6-8 months old. I did buy oil/a filter on Saturday, just haven't had time to change itIt's still good to get out there. :thumbup: I should change my oil too, but that's not going to stop me from riding.
Colin, have you looked at those offset Tom Woods joints?
You should be able to get close to 45* with one of those.
Yeah but I have to get a single cardan driveshaft at that point.
The transfer case and axle end bind up at pretty much the same point.
The guys at Tom Woods also said that they wouldn't recommend it for more than 30 mph as it will be vibrating by that point.
Wasn't saying single w/offset joint...single with flange & toyota joint at the t-case side, single 1310 or 1410 at the axle side with a deeper & ground yoke.
Although the 'economical' thing is probably just to buy two offset joints and see how bad it really is.
I know my front t-case u-joint angle is bad, it's been a trouble spot on the truck since the day I built it. I consider two new u-joints to be a standard part of race prep at this point.
I've probably bought enough yokes/CV parts/u-joints to have paid for a bling shaft at this point, but no one is going to make me a bling shaft with 1.75" OD. I'm fine with that.
Do it
C'mon, do it Sally
Do it
C'mon, do it Sally
