THe NAC Lots-O-BFG KO2 Thread
The HD offroad's are 10ga, right? 0.023 might work pretty well, but I'm sure 0.030 would be just fine too. I find that a little extra heat helps to get a better weld when the material isn't super clean (read: rusty)
Id probably use whatever is in the welder, which is almost always .030 or .035 for me.
Ok, a little extra heat...but what about a little extra (or less) wire? Why would. 023 seem like a better pick, what about thinner wire is better in that situation?
What size wire should i use when i go to weld on the hdoffroad frame stiffeners, and do the rockers? .030? or thinner or thicker? Mig not fluxcore... i figure i can dick around and figure it out, or just ask and see what you fawkers say :)
.30 is fine
Thats what i was thinking would be fine, but i didnt know if i was missing something somehow :dunno:
im wide awake and this is gonna suck when i have to be up at 645.
gay.
I once slept in so I knew I was going to be awake all night but had to wake up at 5am and work for 12 hours the next. So I got hammered, which usually helps me pass out. Stayed up all night, went to bed at 4:30am. Got to work right on time, worked all day, it was a great success.
The frame is thin but it's not sheetmetal, you'll be able to weld it just fine. I believe in you.
i should have drank.
what sucks is i had the opportunity to go out and drink and possibly bang this chick.. but i though, i have work in the morning and i feel kinda tired. got home, took a quick shower and BAM wide awake the second i hit the pillow.
Don't take a page from colin's book. When you're welding and it looks like shit, DO change the settings. Settings are 95% of mig welding. Get the right setting and it's like a glue gun.
gay.
x2
.023 would let you have a more appropriately sized weld throat. But trying to weld to the unibody is such a PITA. I've had better luck throwing a bit of extra heat and wire into the weld, that's just where stitch welding comes in.
You'll probably want a fairly high feed rate. You run the risk of burning through if you go slow.
Carmelo has spoken: .030 it is.
Im gettin up at 0630 if it makes ya feel any better adam :)
:thumbup:
Technique is important, but good technique with bad settings and your weld will suck.
I have to be at the airport at 3:30-4am saturday morning, if it makes you feel any better adam?
Alright man, this is only theoretical and dangerous.
Go out for a run, achieve a runner's high and come back inside. Sit on the toilet, start taking a giant dump. As it's on it's way out put a cotton swab in one ear and start masturbating like a madman as everything leaves your body, shoot up some heroin. You can stop cleaning your ear, you are now asleep.
:thumbup:
Technique: pull trigger, drag gun over metal:thumbup:
a tad bit, not so much if youre going somewhere awesome
holy lol
