THe NAC Lots-O-BFG KO2 Thread
I would have never thought the grandmamobile ford taurus was viewed as cool in any, way, shape or form, especially it's drivetrain.
I still dont view them as cool in any way, shape, or form.
I just logged into SHOforum.com for the first time since jul 1 2006.... wow. Even more impressive, I remembered by username and password first try.
edit: http://www.shoforum.com/member.php?u=778 some sick bastard signed up for a forum on 9/11.
^^ Mark must be using Colin's computer!
HMMM
if a variation of the aw4 came behind the toyota 2jz. then that means you can make an ax15 bolt up to a 2jz. which means you can make a billiondy trannies bolt up to a 2jz.
yea. if i wanted to XXXX with any motor swaps for performance, i would 2jz that bitch.
AMURICAN v-8's are cool and all, but everyones aunt has them, and they weigh a billiondy pounds. but the sound makes me happy.
i always found it odd that vdub diesels will bolt to an ax5 as well.
If a 4.0 weighs a bit over 500 lbs (which is an estimate based on what I've googled), and a 440 weighs right around 650 (save some with aluminum heads), then I'm pretty sure the added weight isn't going to make too much of a difference.
Why don't one of you faggots put your money where your mouth is and make your own engine if you enjoy being so unique and self expressive.
i just think a 2jz would be sweet, and it isnt done by everyone and thier mom (yet)
realistically though. i'd probably keep the 4.0. less crossover/conversion parts. which is nice, because i like simplicity and ease of repair/maintenance.
I'll just keep my 4.0 and cut a hole in the floor under the throttle pedal so I can push it further.
I know you just said this to be funny but I actually did this in my comanche.
1. you were correct
2. hahaha wow.
3. I don't have to do this in my comanche, all I have to do is remove the carpet
IIRC, the main difference between the jeep AW4 and toyota version is a different bellhousing, thus it might be a little tough to quickly "bolt up" an AX15 to it. Of course, with enough money and suck you can mate any engine to any tranny.
69Liter Carmelo's Dick > 12.5L Nacho Supreme
different bellhousing and input shafts, torque converter, gears, etc. One of the guys on here (child9 iirc) has a thread going, his transmission guy ended up transplanting the back half of an AW4 onto the A340 instead, so he basically has an A340 that will bolt to an NP231.
