cmelo
- Stoughton,MA
I just realized Ken's screen name is his name K-A-Stein
It's still closer to being on tons than mine :gee:I shouldn't be giving build advice.
I don't even know if mine works yet.
:laugh:
I'm following Rob's school of suspensionROBZ95XJ's how to build a 3link
basicly do everything like ktmracer cept dont bother with a calculater
That probably depends on whether you have to call the FAA up for clearance every time you wheel it :roflmao:
You're going to have problems with the link mounts being on the frame and having clearance for your tires especially with H1s.
Here's an idea of full lock driver with H2s and 40s.
Fawk. Looks like I can add a crossmember to that list.My Jeep has the links mounts on the frame rails and I wish they weren't. With the H2s and 37s it still rubs at full lock. Someday I want to build a new crossmember and redo the lowers.
Building the crossmember to me was really fun and not that bad.
Bobbing the bed and doing the wheel wells is going to be ghey.
This is making me want to weigh my wheel/tire setup.
basicly do everything like ktmracer cept dont bother with a calculater, instead eats lots of shitty chinesse food, that will fix yo anti squats
Exactly. Nothing much to worry about up front it isn't like building a link setup out back.to build a 3 link:
figure out where you can fit your link mounts
measure some shit and put it in a calculator
move links around a little bit here and there until you have a sweet antisquat %
brag to your friends about your awesome antisquats
weld some mounts where yo sweet percents were
wheel
:laugh:cept dont bother with a calculater, instead eats lots of shitty chinesse food, that will fix yo anti squats
Can't mount them to high of you get in the way of the t-case output.i kinda wish i built my own cross member, i think i would modify the frame rails so the arms sit higher without having to inboard em
Good luck. You'll need 2" backspacing and spacers to make them fit.I also plan on be able to also fit 4D's after the treps die. I don't know how, but my rob style backspacing will make it happen![]()
