asp
- Westport, MA
I thought Rossy & Ken might still have a 231 hanging around f/s...was I wrong?
if he can get it to me... :moon:Travis, it sounds to me like Ken just volunteered to fix yo jeep.
Awesome comic.
Mark has two, one from a '99 auto, and one from a '98 manual with AA SYE installed.
How much does he want to pay? (please don't give him my number, I'm just curious)
After 185 incorrect miles, the evap system still is showning "Not Ready" on my scanner. The htd o2 sensor just went off. So much for under 100 miles.
That sure buys a lot of flap wheels.Also... I think I might buy one. Votes?
http://www.vansantent.com/tube_coping_machines/Notchmaster.htm
http://www.pro-tools.com/hsn500.htm
Damnit Travis that's like the first test to do.
Wait, correction, first test is grab a big blunt object and smack the starter a couple times.
Travis, I put my die hard gold on a tender last week. any time you need to borrow it just lmk
Travis, you HAVE to get that jeep running. Isn't it the official "pulls everyone in NAC out" jeep for the snow run?
I'd bet on something screwy with the ignition switch or the battery wiring.
This is not the first as it can damage the started so I hear. Start with wiring/solenoid before you start wailing the starter with a heavy object.
If it hasn't been mentioned check the voltage at the started with the key on. It should be atleast 11.5v and atleast 10.5 while cranking IIRC. If that's not case your problem would lie elsewhere.
(so yes, assuming I'm around and he drives it down. I don't have time to drive up there right now.)
IMO, don't waste your money man. You're going to be doing one cage not a shop production. I did all mine with either a cut off, grinding, or flap wheel. Did it take twice as long? Sure, but I still had near perfect notches.
i cut my tube with an angle grinder and fill in the gaps with boogers
I got a jar of this for christmas![]()
This stuff is so good. It's hotter than any big name brand, but not nearly as hot as that stuff I ordered. It's just delicious.
I know 2, and neither are interested in me, or any other guysEvolved? When the female species evolves to wanting to spend 6 nights a week wrenching at the shop, the world will be a much different place.![]()
http://www.googlefight.com/index.php?lang=en_GB&word1=Foxwar71&word2=Jeepman401I challenge somebody to try and get a lower score then me. I got 3 results.
