billyjp2
- Indian Orchard MA
anyone from here going to the UJ christmas party?
black phosphate is the coating, think black oxide, looks about the same iirc. black phosphate might be the shiny carbony looking one instead of the dull black one.I want these from McMaster. I have no idea what phosphate Grade G steel is, but it sounds cool.
Black-Phosphate Grade G Steel Flange Locknut 5/8"-11 Thread Size, 15/16" W, 39/64" H Overall
$13 for a pack of 20.
where is it?
we rented the hall (with a bar and bartender) at the Century Sprotsman Club in Auburn on january 8th
Why flange nuts? Why not run a traditional washer and mechanical locknut?I want these from McMaster. I have no idea what phosphate Grade G steel is, but it sounds cool.
Grade G is essentially the same as Grade 8.black phosphate is the coating, think black oxide, looks about the same iirc. black phosphate might be the shiny carbony looking one instead of the dull black one.
I have no idea what grade G is, and neither does http://www.americanfastener.com/technical/grade_markings_steel.asp
X2.I just might have to show up.
Billy, I'm planning on being there.
Gonna be at the NEA meeting that day too. Figured it was about time to pull my own weight and it's at a fairly convenient location for me this time around. My only question is what the hell am I supposed to do, take notes or rabble rouse, etc?
we made it a shorter drive for you this year
I'm not sure I am cut out for this kind of task :wow:The only thing to do is try and stay awake
Because flanged nuts are more expensive. If you ever have to take the link out you gotta replace the flanged nut vs reusing the washer and being able to just get a new nut.Why NOT a flange nut?
Huh?
HOW ABOUT THAT?!!
A buddy of mine ran them on a ZJ for awhile and thought they did pretty good on anything with pavement (be it snow covered or not), offroad not so hot. They did wear quick though.i also just purchased some truxas STS, anyone know how they are in the snow? i only bought them because of the price and im sick of running stock bald tires.
Dumb to reuse a mechanical locknut, flange or not.WTF are you talking about?
I've reused factory flanged locknuts COUNTLESS times without issue.
So have I, but that doesn't mean it was the right way to do things.WTF are you talking about?
They don't hold as tight after the first use. I had a UCA nut work its way off a while ago. Never had an LCA bolt come loose though and I reuse those every time (if they come out clean and I didn't have to use heat.)WTF are you talking about?
