THe NAC Lots-O-BFG KO2 Thread
:doh:
hmm ok so i think i have this figured out... my trac bar set up for the WJ stuff will consist of: RE 1665 and 1670, small summit flex joint, 6-8" tube welded to the flex joint, one end threaded, 1.25" threaded rod, other tube with 1.25" threads, to poly joint and probably the JKS OTA bracket.
just called mike back. he approves of my master plan.
ross, you ruined it. i almost had all the posts on this one page.
i'll have to try for page 338 then...
aouaoeu
how many posts are on 1 page anyway...
more than that...
more than this.
maybe that was the last one
geeeeez...
travis i'm catchin up.
let's go for one more.
oh.... problem solved then. did you get ones with a shank?
Yes, I got one with a 3/4"-16TPI shank and one without. I think that should be plenty.
So did you order anything?
Have fun paying for LH 1-1/4 - 12TPI B& threaded rod... the RH stuff is expensive enough! Plus, the 1-3/4" tube I think is overkill (and you might have space issues), but who I am to stop anyone for that? Haha.
overkill is the best!!!
indeed :)
