THe NAC Lots-O-BFG KO2 Thread
So i'm getting that pro comp track bar for Melissa's Jeepy but it needs a new heim joint. I'm leaning toward getting a ballistic joint instead of a plain heim joint. What do yous guys think?
i also recall it bein a lil cooler today then the past week
No matter what temp it is, when ever I get into my parking garage, the temps have always climbed. That didn't do it today.
I'm not saying that this is the cure to everything, I'm just saying there is a difference from before so far.
do you like waiting a long time for stuff to ship, then when it does arrive shits missing?
i believe theyre intended to be run in a single sheer setup, i would use another heim. no reason you couldnt use a bushing joint like the JKS setup though.
there are 2 things wrong with that
1 is pro comp
2 is ballistic
Pics or it didnt happen. And yes, I'm too lazy for FB creeping to see if there are any.
gotta wait for the wimminz with the cameraz to uploadz
who should I order from then?
1 is pro comp
2 is ballistic
I think the track bar will be okay on her Jeep. She'll barely wheel the thing anyways.
Wutta 'tard!
Keith: WTF did this guy do!?
Rob OKAY!!! Just PM me your address and i'll have them shipped over LICKETY SPLIT!
If you look to the right you see a hi-Lift and to the botom left there is a jack stand laying down. I think it fell off the hi-lift before he got the stand underneath.
so the guy was playing around with his leaf pack with a truck that was held up with a hi-lift on a stock bumper??? NIIIIIIIICE!!!
yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes give it to me!
All the brakes on the mj work again :thumbup: I nearly ate the steering wheel the first time I stopped after fixing them, so used to using the brakes the way carmelo uses the gas pedal. Speaking of which cmelo if you want the old gas tank it is all yours if you don't get one from colin (forget if he was gonna give you his or not), I am not sure if it has any leaks but either way yours if you want it. Also I picked up the mj tailgate at sams, cost 35 bucks, I can hold onto it as long as you want or throw it on the classifieds if that's too much for you to want it.
Taught my brother to weld sorta also... He welds like I used to, kinda booger-ish :roflmao:
