Here are the trails and a "rough" description about each that will be available this year
#1 Easy Trail Class 6 (10 vehicles MAX)
Traveling on unmaintained roads and occasional travel on maintained roads, generally the roads have some rocks with occasional obstacles. Recommended for new trail users, stock vehicles, or lightly modified vehicle.
#2 Easy Trail Class 6 (10 vehicles MAX)
#3 Harder Trail Class 6 (10 vehicles MAX)
Traveling on unmaintained roads and occasional travel on maintained roads, the roads will be more challenging than the other Class 6 rides and have more obstacles and technical areas. Recommended for lightly modified vehicles or an easier ride than private properties.
#4 Moderate- Carnage Hill: MINIMUM 33inch tires (10 vehicles MAX)
Trails are on private property with permission. Travel on tight off-camber trails and on wide open powerlines.
#5 Moderate- Frost Homestead MINIMUM 31inch with Rear Locker or Winch (10 Vehicles MAX) *PLEASE NOTE THAT DUE TO TRAVEL TIME, THIS TRAIL WILL REQUIRE THE GROUP TO DEPART AT 8AM FROM GRETCHEN?S AND DEPART NO LATER THAN 4PM FROM THE TRAIL TO HEAD BACK FOR DINNER SATURDAY EVENING.
Trails are on private property with permission. Travel on trails with some boulders, climbs, and tight spots
#6 Moderately Hard- Carnage Hill: MINIMUM 35inch tires, 33inch with Locker (10 Vehicles MAX)
Trails are on private property with permission. Travel on tight trails with boulders and climbs
#7 Moderately Hard - Wayne's World: MINIMUM 33inch with Locker (10 Vehicles MAX)
Trails are on private property with permission. Travel on uphill climbs with boulders and some granite step climbs. Some spots can be tight.
#8 Moderately Hard- Swanzey MINIMUM 33inch with Locker (10 Vehicles MAX)
Trails are on private property with permission. Travel on uphill climbs, granite ledges, and some steep descents. Trail can be very tight for wider vehicles.
#9 SATURDAY ONLY OPTION: Moderately Hard- Moose Mountain, Springfield. MINIMUM 33inch with Locker (10 Vehicles MAX) *PLEASE NOTE THAT DUE TO TRAVEL TIME OF 1 HR & 15 MINUTES WITH SOME HIGHWAY TRAVEL, THIS TRAIL WILL REQUIRE THE GROUP TO DEPART NO LATER THAN 8AM FROM GRETCHEN?S AND DEPART NO LATER THAN 4PM FROM THE TRAIL TO HEAD BACK FOR DINNER SATURDAY EVENING. Trails are on private property with permission. Travel on uphill climbs with boulders and some wet spots. Some spots on the trail can be tight.
#10 Hard - Wayne's World: MINIMUM 35inch tires, 33inch with Locker (10 vehicles MAX)
#11 Hard - Gretchen's: MINIMUM 35inch tires, 33inch with Locker (10 vehicles MAX)
Trails are on private property with permission. Travel on uphill climbs with boulders and granite step climbs. Some spots can be tight.
#12 Hard- Wombass Pass - Swanzey: Minimum 35inch tires, 33inch with Locker (10 vehicles MAX)
Trails are on private property with permission. Travel on uphill climbs with granite step climbs. Some spots can be tight.
#13 Extreme - Wayne's World: MINIMUM 36inch tires Lockers, Winch, and full cage (8 vehicles MAX)
Not for the faint of heart, poorly equipped, or lightly modified vehicle. Spare vehicle is recommended - at the bare minimum, bring your tools! Trails are on private property with permission. Travel on very steep uphill climbs with large boulders, granite step climbs, often off camber. Many spots can be tight.
#14 Extreme - Wayne's World: MINIMUM 36inch tires Lockers, Winch, and full roll cage (8 vehicles MAX)
#15 Extreme- Frosty's Private Reserve: MINIMUM 35inch with Front and Rear Locker, Winch, and Full Roll Cage. No children please. No exceptions per landowner request! (10 Vehicles MAX) *PLEASE NOTE THAT DUE TO TRAVEL TIME, THIS TRAIL WILL REQUIRE THE GROUP TO DEPART NO LATER THAN 8AM FROM FIELD & FOREST AND DEPART NO LATER THAN 4PM FROM THE TRAIL TO HEAD BACK FOR DINNER SATURDAY EVENING.
#16 Hard to Extreme - Gretchen's: MINIMUM 36inch tires Lockers and Winch (8 vehicles MAX)
Not as extreme as #17 but more challenging than the hard group. Trails are on private property with permission. Travel on very steep uphill climbs with large boulders, granite step climbs, often off camber. Many spots can be tight.
#17 Extreme - Gretchen's: MINIMUM 36inch tires Lockers, Winch, and full cage (8 vehicles MAX)
#18 Extreme - Swanzey: MINIMUM 36inch tires Lockers, Winch, and full cage (8 vehicles MAX)
