Bronzewyrm
- Independence,or
more pics...
![S7300173.jpg](/proxy.php?image=http%3A%2F%2Fi387.photobucket.com%2Falbums%2Foo317%2FBronzewyrm%2FS7300173.jpg&hash=e5e57c7510da263de2bd663f5ea54b94)
![S7300174.jpg](/proxy.php?image=http%3A%2F%2Fi387.photobucket.com%2Falbums%2Foo317%2FBronzewyrm%2FS7300174.jpg&hash=c18b5ce60a953e5df538e1a89f529277)
![S7300180.jpg](/proxy.php?image=http%3A%2F%2Fi387.photobucket.com%2Falbums%2Foo317%2FBronzewyrm%2FS7300180.jpg&hash=01743e5d7ff10a3821540d4a12da2624)
![S7300182.jpg](/proxy.php?image=http%3A%2F%2Fi387.photobucket.com%2Falbums%2Foo317%2FBronzewyrm%2FS7300182.jpg&hash=23644f1541e3bd3ac9e51903d60e8084)
![S7300175.jpg](/proxy.php?image=http%3A%2F%2Fi387.photobucket.com%2Falbums%2Foo317%2FBronzewyrm%2FS7300175.jpg&hash=2864f03756b33d8c296264101174bf39)
I don't want to come off as an a$$ or anything. But those welds are pretty cold and stringy and I'm sure they don't have much penetration. If I were you I would grind them down and find someone with a good size 240v welder to do some aggressive hot passes over them.
Im only telling you this because I don't want to see you stranded somewhere with a major to impossible repair to get of the trail and 90 miles home.
Dave
Build looks nice. I think dellstop's longarm was one of the first ones my brother in law built. Got some nice upgrades in there now.
Hey Bronze! I forgot about this build thread too! I had to go back and "refresh" my memory on the progression of this.... I thought you had Duratrac's on that thing before.... is that old? Or are these a different size? Good idea by the way on the ZJ cross member... I may have to go junkyard digging. (still need to get with you about my fender/header panel painting.)
Bronzy FYI your upper spring plate is on wrong, the bent side needs to face the spring. the square edge the way you have it has the potential to break your leaf spring. thats why they bevel them that way.
Durring mockup i noticed the front had massive flex potential, on the driver side the driveline was actualy going to make contact with the crossmember at full droop, i actualy had to raise my trans/case mount up about 1.75" higher than stock in order to keep the DS off of things. because of this i had all kinds of linkadge issues. in order to solve this issues i needed to cut a section of a linkadge arm and shotren it, aswell as replace the 10mm adjustment set screw with a rounded head allan head bolt. now i have a shorter throw on my 4x4 shifter. and i dident have to go cable. whild welding the linkadge back together i melted some plastec inserts, making my linkadge fail at times.
http://s387.photobucket.com/albums/oo317/Bronzewyrm/jeep resto/?action=view¤t=0528121648.mp4
the first time it moved in 6 weeks under its own power. i had to drive it home with no rear brake lines in it and no rear bumper. i was out of time, i had to be out of the shop.
i slacked on pictures on the rest of final adjustments. i had my WP rocksliders up for sale for along time, my plan was to do rocker replacements, but i ran out of time, and all i got for offers of the sliders were Lowballs. so i bolted them back up to the pinch seam, and welded the to the new stifeners.
from this point i had 2.5 weeks to break in the front gears(500miles) and change the fluids. also dial in my caster and coil bucket location, install bumpstops, shake it down, fix post shakedown, prep for nwfest. i was still feeling the crunch.
well the weekend befor Nwfest, Mopar440 and i went on an outing to tsf. he had a new XJ and i had a new setup. plus we hadent wheeled together in nearly 2 years. so we set off to hit the trails out of rodgers stageing area.
all was going great. i was shocked how stable/predictable the suspention system was working. i was trying to get useto all the new noises under the jeep. it felt great just a little noisy. i figured it was the griz/ausi doing there thing. Flex is no problem!
i got to the famous spot on FB5. nearly folded my rear driveline, the i herd a loud PING, i thaught it was the locker unloading. "i was flexes at full stearing lock" when keith says "your coil is hung up on the bumpstop. i thaught that odd beings i hadent done the front bumpstops yet...
well i sheared the uper control arm link bracket clean off the axle tube.:eyes:
we scrached out heads for a while befor devising a plan to get it up and off of the trail. much less home.
we were letting it roll back and taping the brakes to roll/adjust the caster as close as we could. we broke 3 straps and still were not getting far fast. the axle was just floping back and forth on the LCA's basicly as i hit the throdle or brakes. so we hooked up keith's xj for a little friendly tug action.
after getting off the trail, i bolted the swaybar back up. then i removed the foot from my highlift. and used it to reset my caster back where i needed it. i then took a treesaver strap. wraped it around the crossmember and then back to the panhard bar bracket. this wedged it back. then i took the 20' strap and wraped it from the coils to the bumper to hold my coils forward off of the shocks. this got my all the way home from tsf. into the driveway, where the strap holding the majority of the caster, Broke.
glad i did a shakedown run. Thanks agin keith:wave1: the same night i got it home i welded the mount back to the tube and away i went agin. i used the big welder the second time.
NWFest Prep Begins! i really dident belive i was going to make it...
just read the hole build its kinda funny for the longest time I didnt think this jeep went wheelin until I spoted it finally dirty lol. looking forward to seeing it in action. and in person. good build one nice looking jeep
