CRASH
- Foresthill, CA
......hopefully temporarily!
I was headed down FH road when all of a sudden......it shuts down with not a hint of warning. Shiznit, I thought, the CPS took a dump. Checked it, hardwired it, nothing. After about a half hour, it coughs, coughs, and restarts. Headed for home, and after a mile, it shuts down again.
Long story short, got a tow home.
Got home, changed the CPS, nothing. Checked the fuel pump relay, negative. Pulled thefuel pump, and this is where it gets interesting.
The pump runs when the key is in start mode, when it's getting the run signal from the starter, as soon as I release the key, the pump shuts down. This is why the rig will start temporarily and then die, it gets full pressure for just a couple of seconds.
Checked all the fuses, and everything is intact.
Anyone ever seen this condition? I did smell something electrical as i was coasting to a stop the first time, so something must have shorted somewhere. It was outside in the rain for a while, maybe something got wet (the old bitch leaks like a sieve)? I just don't know where to check next.....
Advice, cheers and jeers gladly accepted.
CRASH
CRASH
