- Cheyenne, WY
Don't forget to make that axle swap a little easier or your stock axle a little beefier, with a T&T Customs axle Truss.
Trusses are available for the following axles,
- Front Truss - D30 (non disconnect)
- Front Truss - D44 (Rubicon)
- Front Truss - Ford HPD44 (leaf spring style)
- Front Truss - Ford HPD44 (radius arm style)
- Front Truss - HPD60
- Front Truss - Wagoneer D44 (80+)
- Rear Truss - D44
- Rear Truss - D35
- Rear Truss - Ford 8.8
- Rear Truss - D60 (low pinion)
- Rear Truss - D60 (high pinion, if it is based off a factory high pinion front D60)
Trusses are available bare so you can add your own mounts or they can be ordered with the UCA mnts (or mount if you have a RockKrawler system), trac-bar mnt, and coil buckets already installed. Trac-bar mounts are also available for Hysteer and OTK steering setups.
Don't Forget, members get 10% off!
- Rear Truss - D44
- Rear Truss - D35
