RCP Phx
- Phoenix,Az
Kristian, you need to re-gear to at least 4.56's for that size tire, 4.88's would be more the ticket!
I think he was referring to a "limited slip".
I've never heard that about a difference in caliper size but you will "most likely" have to change to 16" rims which is a good thing for 35" tires!
Nitro and liberty of the same year works? I need to grab some at the jy for my spare axle shafts.. if a warn hub goes boom on the trail, or a front axle shaft, I want to be able to throw in a spare shaft with the liberty/ nitro rotor ready to rock
On my 2000, I did the WJ BB swap and cross over steering. For some reason the 15" steelies didn't fit. The 2000 XJ, 16" rims did. I am running 31's on 3.73 gearing. I do use 07-08 Liberty or Nitro brake rotors. They are a 'No Drill' option. You give up about a 1/16" on the outer side. I do run 32.5's on '98 XJ. They are a bit sluggish on flat land. Still, OK over all. I'm looking at 4.88 and 35" on my next build. I do run Ford 8.8 with the LS (Limited Slip) on both.
Good to know about this rotor option. Piecing together a WJ swap and the idea of drilling a rotor gave me anxiety.
Wish they said what the brand was. I'd like to stick with Centrics and use the black magic pads.
Rotor is hubcentric, super easy over size holes or Patriot rotors bolt on suposebly. I have not verified just easier to drill wj rotors.
