There is a bypass built into the block and the thermo housing, that allows a certain amount of coolant to flow around the thermostat, so the temp. at the thermostat is closs to what is actualy in the motor. The bypass is at about horizontal or about 3 oclock, it hooks up to the heater and surge tank lines. The reason for the bleed hole (in the oEM themro) is to let the air out of the very top of the system with the thermostat closed (the air that doesn´t make it through the bypass).
If you use a universal gasket you can partially block the bypass (and heater). In some models the thermostat can go in backwords. With the heat sensor activator pointed to the front, the thermostat operates erratically. The early Jeep for sure, takes a special low profile thermostat, the normal thermostat (CHEV or others) can be crushed a little during installation.
I´ve found squeezing the top radiator hose (with two hands vigioursly and repeatadly), when the motor is at operating temp. helps move the trapped air into the surge tank.
I´d install an OEM thermostat (and gasket) with the little sign stamped into it that says this side out/or front, possible what your getting just isn´t getting the job done. With a good OEM thermostat, you can fairly confidantly and move on to something else in your troubleshooting.
I weak fan clutch (at or near idle), will run your temp up a bit, allow the thermostat to open all the way and then when the RPM´s are increased, run a slight surge of cold coolant through the motor, pretty quick. Remember the temp, sender is at the rear of the block and the thermostat is at the front, takes a moment for the thermo to close, after the cold coolant has arrived. Causes some pretty wild swings on the temp gauge.
