T-case/tranny compatibility
its easy to swap over the input shaft or just have the long shaft cut down (that way you only have to take apart one case). i certainly wouldn't let that stop you from changing to a 4:1 case. i have a tj 231 from an ax15 behind my aw4 right now. i just took it apart and had a machine shop cut 3/4" off the input shaft. cost: $30.
matthew
