SYE for 2.5"?
DDCxj
Natick, MA
As of now I am running a 2" lift in the front and 2.5" blocks in the rear. So far I do not have any vibrations but I haven't had it in very long. How much of a lift does it become necesary to put an SYE in? Just want to know if I should start saving or if I will be okay.
Well, that's a bit of a tricky subject there, all Jeeps behave differently, so on some you can get away with it, but on others you can't...
I see from your profile you have a '91, so theroetically you should be fine on an SYE, if you do start to experiance vibrations a 1" transfer case drop is a cheap quick fix as well.
Or...if you want to spend money...
Get an SYE and a good kit from somebody to get rid of the 2.5" blocks :D
Sequoia
thanks, and as soon as I am out of school and done paying loans I will get a real lift.
