SOUTHTEXASXJ
- Odem Texas
8.25 rear and yes 1.25" of spline on output shaft
Make sure that when your suspension is fully drooped and the driveshaft is fully collasped the slip yoke can't come off the end of the xfer case output shaft. Or is the slipyoke somehow fixed to the output shaft so that it doesn't slide?ok I now have the same DS in the front as the rear no vibs sweet only took a hour to do.
how did you find perfect center on the output shaft? i was thinking about how i would go about doing this
how hard is it to pull the shaft out of the tcase?
I have a lathe at work and school i can use to get the shaft perfect
and dont whole kit SYE's come with a new shaft? so maybe i can pick one up from sombody cheap and do this in my spare time, seeing as my jeep is a DD
I just got my yoke from six states distributers on portland OR I got a compnay discount I payed $105. on a side note has any one spring loaded there drive shaft so they dont have to bolt the yoke on??? and no I checked and no wercking yard parts interchange 100%
He whent on to tell me that chevy blazers and dodge dakoda was this way from the factoy and that the dodge has a np27? that had the same tail shaft parts as the 231.
By the way has anyone hacked a output shaft of with a hack saw? I think this might take some time.:looney:
:star:
