Blaine B.
- Northwest Indiana
What do you mean? RE does have a hack and tap SYE kit...
Dude take the time to read a bit before posting. It's already been said like four times that the Corvette yoke will NOT work. The ad clearly states it's for a 1350 u-joint, we need a 1310.
Wrong! That yoke you show is a U-Bolt style yoke. That yoke is not intended to be bolted to a CV style shaft, and consequently the holes in the yoke have a different spacing and will not match up to the holes in the CV on a Cherokee front shaft.
FAIL!!! -- YOU NEED TO READ. It doesn't say 1350 anywhere It does say 1310 and 5-153x quite clearly WTF are you reading?
FAIL!!! -- They line up just fine SEE MINE BELOW!
THE 1963-1964 CORVETTE 3-4 SPEED MUNCIE U-BOLT STYLE SLIP YOKE DOES FIT!!!!!
See picture of mine below
Corvette does use lots of different yokes, so those who say Corvette yokes don't fit are obviously getting THE WRONG ONES.
AGAIN SEE MY SYE BELOW - THE BOLTS LINE UP PERFECT -- IT IS 1310 U-Joint -- It is 26/27 SPLINE!
Go right ahead :cheers:
Any reason why this would not work?
http://www.omix-ada.com/productInfo.asp?itemNo=245341
tellico's description says it pretty specifically: "Omix-Ada Yoke For Slip Yoke Eliminator Kit For NP231 Transfer Case, 1987-00 Jeep Wrangler, Cherokee, & Grand Cherokee"
