Been out of town.
Update on the exhaust.
The shop found a way to get all four camaro cats in which is tough. Then they ran the two sides into a y and then into a twister muffler. It is nice and quite which is what I wanted although having a single pipe is too restrictive, I can feel a significant lost of power. I am going to take it back next week and delete the y then run a dual system to improve flow.
Below are some photos of the work. For most folks doing something like this it won’t be that hard, my setup is difficult because of the rear long arms and air suspension. They really make the rear end difficult to navigate.
Here is the very back, passenger side. You can see my relocated charcoal canister. Had to move it for the longarms too.
Looking rear. You can see how tight it is with the Clayton rear long arm bracing and arms .
Passenger side. If you are needing to meet CA standards you won’t be able to do this since the cats need to be very close to their position and orientation from the donor vehicle.
Drivers side
Drivers side
