GregGA
87 Laredo Galloping Ghost
- Woodstock GA
Got the headliner out today. Pretty brittle in spots, and some cracks. What do you recommend using to strengthen/reinforce the board? Fiberglass resin?
Thats more damage than you originally said. In this case I would use some of the tape or fabric with the resin. Let it dry then apply the headliner fabric. Do not use latex paint as it really has crap adhesion. The problem with sanding is blending when you get to the uncoated area. The naked headliner board won't like being sanded too much.
Why? because the board will easily absorb the resin, which will strengthen it alone. Why go through he effort of using extra fiberglass? Its not like its structural or anything close.
Hell I generally just patch the back side of the crack with duct tape and smooth the front. The glued on headliner fabric then holds the front together.
The headliner is the last part of my restoration. I've owned the Jeep since 87, and I am anal about the Jeep.
When I peeled the foam off, some areas of the board came with it. Not doing headliners for a living, I don't know if the new fabric will lie smooth over the indentations. I don't want to take the chance, so I want to use drywall tape to cover the rough spots. I'll use tape on the back side, and maybe some wood paint sir sticks to reinforce certain areas.
How deep? I've had some peel off as well. It has been invisible after putting the foam-backed fabric on.
The only issue I've had that can be seen is where I've not been paying enough attention and allowed the fabric to buckle. This is more common on sound bars and overhead consoles. As long as you pay half attention doing the headliner board itself is easy.
