So, today was to be a momentous day -- the State is requiring me to drive the Stomper to (1) a dealership to get a VIN inspection since it has a NE title, and (2) a gravel yard so as to get a weight for it (WTF??) before they will let me re-title it and get it plated/registered. Of course to do that I had to get it at least semi-road worthy, as well as go buy paper plates -- the paper plates they will only issue for 10 days, and unbeknowst to me (cause the stupid bureaucrats don't bother to tell you) is that you cannot get ANY renewals of temp paper plates. I bought my first set 11 days ago, and then the wiring nightmare began and it expired yesterday before I could get in for my various inspections... SO, I spent a 1/2 hour yesterday arguing with some paper-pushing POS and convinced them to give me another 7 days on paper plates (I now expire Friday, Oct 5. With mostly working lights (still no rt turn), and a paper plate in the window, I set off this morning to get my inspections, and maybe even pick up some landscape timbers in the process for some wall work since I had to go to Pioneer anyway...
I got roughly a block and a 1/2 from my house -- yes, it was on a public roadway, briefly -- before the steering started feeling a bit, well, sketch. So I carefully backed it into a side street, and prepared to turn back onto Rollercoaster to head home and figure it out. As I went to make my turn back into my driveway, however, the wheel turned more smoothly than usual... and unfortunately the front wheels did not turn at all -- slippage in the sector shaft. After 15 minutes in the middle of Rollercoaster road (with a good samaritan kindly directing traffic for me), I managed to get the shaft tightened enough to pull forward onto the shoulder (mostly), such as it is. That allowed me to get a better look at it, and find that the column shaft splines are completely shot, essentially grooved and smoothed -- the locking nut/allen has created a 1/8" groove in the shaft, and there is just no way it will hold -- I managed to find a little bit of meat to lock to and get it backed up the driveway, but it looks like I've got a couple days here to source a replacement shaft and get it repaired... fun. Oh, and I managed to run over my Oakleys in the process, so I am now again shadeless.
As to the plow, I have managed to adapt the "bumper" portion (apparently 83 F250s and 79 F250s have some significant front frame differences), and have a plan together to get the main plow attachment point fabbed up, but I have to get to the metal supplier first -- pics may eventually follow, if I get around to it
/rant
