Well start with my first question:
My electric fan doesnt work, If I jump the relay it does work. Checked the sensor and when the rig is hot (above 220) the sensor isnt closing. So I assume that it is bad.
So I went into my Chilton books and if the AC compressor doesnt work, the electric fan wont work. I turn on my AC and no AC compressor, cold ac, or electric fan. I check the relay for the AC compressor and im getting a tiny bit of voltage. (Under a volt) so I would say that was a bad connection somewhere. A really bad one at that.
Id like to know what connections I should check for the AC compressor relay.
My second question is what would the coolant temp sensor cost? And if I dont replace it and just run a switch to the aux fan will there be any reprocussions?
