- Denver, CO
I went through the list, however I'm now noticing something on Dallas's page. He states:
-7075 Aluminum tie rod with offset tie rod ends
-7075 Aluminum Drag link with new MOOG tie rod ends
-7075 Aluminum track bar with Cromoly heim joints (Johnny joint optional on frame end)
But then lower down states:
-Optional Upgrade to 7075 Aluminum steering links is available
I assumed the $1,850.00 price tag was for 7075 AL? Is 7075 more expensive?
From his list:
-NEW WJ steering knuckles already machined for over the top 1ton steering - Covered That
-NEW Pitman arm machined for 1ton TRE Covered That
-NEW double drilled Centric brake rotors, Centric calipers, and hardware - Covered That
-NEW Timken Unit bearing Hubs - Covered That
-NEW Dana Spicer Ball joints - Covered That
-7075 Aluminum tie rod with offset tie rod ends - Covered That
-7075 Aluminum Drag link with new MOOG tie rod ends - Covered That
-7075 Aluminum track bar with Cromoly heim joints (Johnny joint optional on frame end) - Covered That
-SFR Lower Track bar mount
-SFR Upper Track bar mount
-SFR Over the Top Sway Bar brackets
-SFR Sway Bar Relocation Brackets
-SFR Bearing Spacers - Covered That
-SFR Spring Bucket Supports
-Necessary hardware
So, the only things I left out are stuff that can be decently easily fabbed (for myself):
- Upper and Lower Panhard mounts
- Swar Bar Brackets and Relocation Brackets
Otherwise...hardware.
I'm not really trying to knock his kit, it's good stuff. But yes, it can be done for less than half of that with top quality parts as MANY MANY people have done. The swap is nothing remotely new, he's just one of the few who's done an "all inclusive" type package.
It's small stuff that Dallas currently just is going to compete with some of the larger guys.
For example:
7/8" x 3/4" Rod End RHT
From Dallas - $30
From Ruffstuff - $19.90, before 20% off
Small stuff like that adds up...which guys who are building a D30 and not tons really tend to notice.
This is the reason I posted this - I sincerely value your input.
The thing I'm grappling with on your above post is, on top of your $760, I would have to buy all of the bracketry, I don't know the prices of the upper and lower trackbar brackets, but I'm assuming it adds ~$200. Your example did not include drilled rotors (added $) I also would need help fabbing the steering.
I *think* I am comfortable spending an extra ~$600-$900 to 1) get it all from one place 2) Not have to dink around with fabbing the steering/trackbar 3) rest assured that it was designed to work together 4) Support a
I am literally still contemplating it though.
