Stillen Front Rotors & Carbon Metallic Pads
FishPOET
La Habra
Up for sale as a package deal for $150.00
I prefer local pick up.
One set of Stillen front rotors. (never been turned)
One set of stock ZJ front calipers.
One set (front) of Performance Friction Carbon Metallic pads with 90% pad left.
One set of well used stock ZJ front rotors.
One set of used ZJ front pads.
http://kevinsoffroad.com/brakes.html
GrimmJeeper said:
because he upgraded
Yep.
Kyung came over on Saturday and we installed new ball joints and a Vanco brake upgrade.
jjmat3 said:
So whatcha think about the Vanco setup and how much & from where?
I got it straight from Van. We test drove it on Saturday and it is a huge difference. Let me get a few hundred miles on the brakes and then I'll post up about how good they really are.
The calipers (dual piston) and rotors are for a Ford Explorer Sport Trac and the pads are Posi Quiet Ceramic (pre scorched) The setup fits in 15" rims. $800 inclusive.
Does he offer the knuckles modded for OTK steering? Was there a core charge for the knuckles? Is it made for stock rotors? Did it require replacing the master cylinder? Are you tired of my questions yet?
I don't think he offers them....but he has a complete machine shop and I'm sure if you had enough time he could machine your knuckles to accept the new calipers.
Normally there is a core charge.
No
No.
If one asks many questions about knuckles does that make them a knucklehead?
Check http://www.vancopbs.com/category_s/121.htm for more answers to other questions you may have.
If you have a specific TRE you are flipping over to the top of the steering arm, let Van know and it's very likely that your needs can be accomodated.
Yes, a core charge is necessary to get folks to replenish Van's core box.
No, it won't work with stock rotors. The kit includes everything you need to swap the kit onto your existing set-up except mechanical ability, tools, and want to.
All the kits so far are designed around a 1" bore master and a dual diaphragm vacuum booster.
No
