B.Styles
- South Jersey
Rotary, I'm sure you can make on fit in there. Low cg, can make great hp. That or a 2jz, that's
a 3liter. Just think 1000hp mj.
I think I recall reading that a 4.0 TB will bolt in and then you can open it all the way to 62mm if you want.
'Have to disagree here. On asphalt, big difference. In dirt/gravel, it's hardly noticable. I do agree with the tru-trac. If you're going with a L.S. dif. they're probably the best out there. They come up used on EBay all the time and usually sell for $250-$300.(Nothing to wear out, so used is pretty safe with this one)I would keep a limited slip outfit in the rear. Lockers/Spools will negatively effect steering.
I really like the Detroit TrueTrac.
Summit has a universal elec water pump drive kit you can retrofit to any water pump. Also, ditch the engine driven fan. People report a huge difference on the 4.0s, the 2.5 would wake up even more. The fan's also a cheap mod. (all JY components)Is there an electric water pump avail. for that motor?
You can try this, but all the go fast guys I've met/talked to use them.Ditch the front sway bar during testing..
Consider the Bilstien 7100s They're not a lot more expensive the the 5100s, and are rebuildable and revalvable.new shocks (bilstien 5150?)
Keep the rear bumper. It'll weigh more then a roll pan. Try shifting the battery to the bedput some weight over the axle for bite
Dump the rear bumper and roll pan it
4cy TJs and YJs had 4.10s form the factory, but would have to have perches welded on to swap under the MJ. The popular swap here seems to be a Ford Explorer rear axle. It gives you an 8.8" ring gear, (a tab bigger then the Dana-44) 4.10 gears, disc brakes, and usually a limited slip dif.Would like to do:
Find a rear end with 4.10s or higher
Not a lot more expensive = twice as much? Is it really worth double?Consider the Bilstien 7100s They're not a lot more expensive the the 5100s, and are rebuildable and revalvable.
