92 Green YJ
- San Diego, CA
the pricing has not been released yet, I actually need to talk to Mike and get his ballpark numbers.
That's been solved....weld the tubes!:doh: :wave:Ghost said:To bad they cannot solve the issue of the spun axle tubes.
I think you missed my sarcastic point that it was a crappy axle out of the box and needs issues addressed. IE: c-clips, & spun housings :wow:BillR said:That's been solved....weld the tubes!:doh: :wave:
Ghost said:I think you missed my sarcastic point that it was a crappy axle out of the box
No, you were being given the benefit of the doubt.Ghost said:I think you missed my sarcastic point that it was a crappy axle out of the box and needs issues addressed. IE: c-clips, & spun housings :wow:
92 Green YJ said:1. The kit uses 31 spline, 4140 chromoly shafts which are drilled and threaded for dual bolt patterns, both 5 on 4.5" and 5 on 5"
92 Green YJ said:correction on the alloy. the shafts will be heat treated 4340 chromoly.
XJ_ranger said:sounded good till i read that... :wow: remembering this thread -
http://www.naxja.org/forum/showthread.php?t=75669&highlight=santa
91 Jeep Project said:Get a little yellow paint in your eyes?
XJ_ranger said:even then - 4340 is much too brittle a material after heat treatment to take the shock sideload from a semi-float rear end...
I've heard that too, but I think Superior knows just a little more about axle shaft technology than all of combinedXJ_ranger said:even then - 4340 is much too brittle a material after heat treatment to take the shock sideload from a semi-float rear end...
BrettM said:I've heard that too, but I think Superior knows just a little more about axle shaft technology than all of combined
