Speed Wobbling
Nolaws
Santa Clarita
I have a 1998 Jeep Cherokee Sport with a 4.5 inch Rough Country lift kit on it and 31x10.5 mudder tires. Several months back the stabilizer bar bolt sheered off on the freeway and made for an extremely rough ride until I could bring the Jeep to a stop. I fixed the bolt and then I had no problems until the last few days. If I take the truck on the freeway and hit a sizeable bump in the road the front steering will start to shake and I have to get it down to around 20 mph to get the shaking to stop. The truck does fine around town but it seems like once you get it over 65 mph and hit a bump it really starts to wobble. Any ideas what might be wrong or possible fixes?
Robert
First start off with checking the balance of the tires, and the alignment of the front end. If it still does that afterward, then you'll have to start looking at the components in the front. I had to replace the tie rod and the track bar with an adjustable track bar to get the wobble to disappear.
This is what I was looking for:
The first steps to eliminate death wobble should be a visual inspection of each component, check the bushings, tire balance and an alignment. These are some common things you must check anytime you lift your Jeep. Death wobble is experienced mostly on lifter Jeeps, however it is not uncommon for someone without a lift to experience the dreaded DW. Listed below are a few things you can check.
Check your Track Bar, play in this can cause the axle to shake.
1. Bushings - check to see that they are not worn. Looks for cracks, and excessive play)
2. Angles - this angle should be the same as your draglink. Use an angle finders you can get at sears to determine this, don’t just eye-ball it.
3. Bolts – Make sure all bolts are tightened down to spec (some lift components have a different torque spec then)
Check the Axle, your mounts may be worn
1. Check the axle mount. Here is a good write up on a wallowed out bolt hole
http://www.jeepin.com/features/trackbarfix/index.asp
2. Check your Universal joints, a binding or lose U-Joint can cause DW
3. On the frame end if you still use the conventional Tie Rod End or (TRE) make sure that there is no play in this, as play can cause DW.
4. Look/Check for worn/torn boots on ball joints/tie-rod ends.
Check your Tires
1. Out of balance tires can cause shaking in the front end, which can lead to death wobble.
2. Make sure all of your lug nuts are tight, (Sounds elementary but it happens to the best of us)
Check your Frame
1. Small cracks in the frame can cause the steering box to feel loose, Shaking from DW can only make this worse. 33’s and larger should have some form of Steering box brace, or frame brace in.
2. If you have upgraded your frame mount, make sure its cranked down nice and tight. (best to use an impact gun)
3. A busted Frame Mount can cause play in the front end causing DW (Keep a watchful eye on the welds as welds in sheer can break over time.
Make sure you have a good alignment
1. After you get an alignment done, have them print out the numbers for you. An XJ should have a 7* positive caster angle. A lifted XJ can’t always have that high of a number because the pinion would become out of alignment with the front driveshaft. Pinion angle takes precedence over caster.
2. Make you sure you go to a place that will adjust the caster if necessary (either by shims in the frame side of the LCAs, or adjustable LCAs).
The more adjustable parts the easier it is to tune in your suspension.
1. Adjustable Track Bar
2. Adjustable Upper and Lower Control Arms (upper ones above 4” of lift). Not only are they adjustable, but they are stronger.
Things to remember:
1. After any lift, get your Jeep professionally aligned, this is a REQUIREMENT, not a suggestion.
2. A Steering Stabilizer (SS) is not a quick fix for DW.
3. Make sure that the lift you purchase comes with all the required parts for a safe driving vehicle. (as long as its going to be a DD)
4. PLEASE ALWAYS DRIVE WITH YOUR FRONT SWAY BAR CONNECTED!
Entire list of everything that can cause death wobble:
-Front tires out of balance
-Front alignment out of spec
-Loose track bar
-Worn track bar bushings
-Worn track bar end
-Needing an adjustable track bar
-Bad bushings/joints in control arms
-Worn/damaged steering stabilizer
-Worn/damaged shocks
-Worn/damaged tie rod end
-Bad U Joint
-Bad ball joint
-Loose frame mount
-Steering box looseness
-Need drop pitman arm
-Driveshaft(s) not balanced
-Bad front hub assembly
Torque specs:
Item ........................................ Ft. lbs. ................... Nm
Lug nuts (1/2 X 20 w/ 60* cone) .... 85-115 .............. 115-150
All tie rod ends .....................…..... 55 ...................….. 74
Steering (both ends) ..............…..... 55 ................….... 74
Shock absorber upper nut .............. 16 ................….... 22
Shock absorber lower nuts ............. 17 ................….... 23
UCA frame end .....................…...... 66 ..............…..... 89
UCA axle end .........................….... 55 ................….... 74
LCA frame end ......................…..... 85 ...................... 115
LCA axle end .........................….... 85 ...................... 115
Track bar frame end ..............…..... 60 .................…... 81
Track bar axle end .................….... 40 ..................…... 54
Track bar bracket bolts ..........…..... 92 ...................... 125
Track bar bracket nut .............….... 74 ....................... 100
Track bar bracket support bolts ...... 31 ....................... 42
Hub bolts (3) ............................…. 75 ....................... 102
Hub- axle bolt ..........................….. 175 ..................... 237
Information provided by Jeeps Unlimited
Im having a strange bout of DW I have gone through and replaced my Ball joints all 4 UCA bushing LCA's brand new tires my V8 grand tre seems good I can move it forward and back about 3/4 inch or so I check it compared to my buddies rig and they are the same and he hase no DW. My track bar is good stabilzer in new as are the shocks (8 months old) So when my rig has sat over night it has DW in the am for about 5 to 7 miles then it only has some 55 vibesnot too bad.I have a disco and a slightly worn driverside axle ujoint I can just barely wiggle it and I mean Barely.My hubs feel good tight and spin smooth is there crap Im missing ???
Never heard of it being too tight. What have you changed recently?
When you say there's 3/4s of an inch of play in your "tre" You mean the whole Tie Rod or just the tie rod end? Mine has zero play in it.
Nothing on the front end of a Jeep should have 3/4" of play in it.
with the tires on the ground Have someone turn the wheel back and forth while you look at all front end components especially the Trac bar ends, replace anything with slop
This.
Some of the stuff in that big assed long post about DW is irrelevant. Like u-joints, never seen bad u-joints cause DW, cause vibratrions but not DW. Also, a new steering stabilizer cures DW many times, so that info in that post is also wrong.
I agree, never seen a u-joint or drive shaft cause death wobble. I agree with every thing else in that post.
You're saying that a steering stabilizer is a proper way to fix DW?
I have replaced every bushing involved with the front end including swaybar uca and installed new lca's with rubber lower bushing and Jonny on body end.It is the whole Tierod assembly that moves forward and back but when someone turns my wheel back and forth everything looks to be tight.Im going out to give it a alignment now so maybe its wonky I do have some play in my steering box in has a slight clunk when shaking back and forth on the steering wheel.
Check your Tires
Check your Frame
Things to remember:
-Loose track bar
-Worn track bar end
-Bad U Joint
-Bad ball joint
-Loose frame mount
Torque specs:
This is a great collection of information! Do you mind if I pass this along to my local club?
Sure, do what you like with it. I didn't do it. I ganked it from another poster.
But I might add what Richard pointed out is correct. The part about u-joints and drive shafts is goofy. Those things don't cause DW. Vibes, yes. DW, no...
Well the ZJ links are ok Grrrr they only move the way the are supposed to move ???? Damn it so Im going to try and tighten up my Jonny joints untill they dont move at all I guess because one moves a little and the other I just cranked down tight so maybe one being a little loose and the other being tight is hopefully the issue .
