RWKHausSupply
- yorba linda, Cali
Only till Christmas!
$266 gets you the famous Spartan locker for the Dana 30 (fits both high pinion and low pinion open carriers with NO needed gear setup required for install).
This price includes shipping to all states but WA and TN, these are slightly higher.
The Spartan Locker, by USA Standard Gear, provides reliable traction at a low cost. Give your vehicle great traction and save some cash. Choose a Spartan Locker for better traction.
The Spartan locker by USA standard gear is a mechanical locker that replaces the spiders in a standard case. The Spartan locker's design does not use the thrust washers and has a revolutionary spring and pin design that makes installation a snap!
The couplers and drivers are made from 9310 steel, for added strength. Each Spartan locker carries a one year warranty against defect.
THESE COME WITH THE RECOMMENDED CROSS SHAFT THAT ALL THE OTHER INSERT LOCKERS RECOMMEND AND CHARGE YOU EXTRA FOR!
