Dana 35 C-Clip Eliminator Kit by Superior Axle & Gear
1995-06 Jeeps with 30 spline axles
Dana 35 axle housings with disc brakes and drum brakes
35% Increase in strength over stock applications
Two USA-made 30 spline 4340 chrome molly axles
Thicker flange and increased radius to the body for a real strength increase
The Dana 35 C-Clip Eliminator Axle kit features a 50% Increase in strength over stock applications. The system fits 1991 to 2006 YJ, XJ TJ Jeep Dana 35 Axle housings with drum brakes ONLY. The kit comes complete with the following: Two USA-made 30 spline 4340 chrome molly axles. The axles feature a thicker flange and increased radius to the body for a real strength increase for those side hill moments. This design provides more strength than some aftermarket designs that only increase the thickness of the flange. Two heavy-duty machined axle retainers with spacer rings. Complete set of 1/2 ton Timken Roller Bearings™ and Seals. Two Billet steel C-Clip eliminator housing ends, Ten 1/2-20 thread in studs. The Dana 35 C-Clip Eliminator requires no cutting or welding, however does require a couple simple holes to be drilled with the supplied drill bit. On average it can be installed in your driveway in under a couple hours.
