So Cal Karma 2008
Status
Not open for further replies.
Leep said:
Where is it leaking from ? Does it have the plastic tanks on it ?
yea it has the plastic tanks. it seems to be leaking from the connection between the tank and aluminum part on the passenger side. It probably could have been solved by some of that leak stop stuff, but I've heard that it can clog other stuff like the heater core too, so i didn't want to mess with it.
tow bar, remote relays, D44 wheel cyl ubolts, amp, etc
See picture. Each free or 6pack of IPA. depending....
D44 rear wheel cyl new in box
to bar no mounts though
Amp
Remote relay setups (3)
Leaf spring center bolts
D44 rear ubolts and plates with sway bar mounts
rear axle sway bar weld on mounts. For XJ or TJ but good for Many other projects, has fited threaded inserts in ea.
Oh forgot theres also semi new rear hatch struts there also...
Re: tow bar, remote relays, D44 wheel cyl ubolts, amp, etc
Amp
Robert, I will take the tow bar in exchange for the disc calipers I gave you a while back.
Leep
Leep
Sure thing. When and where.
I will take these, please....
yours
Leep said:
Robert, if you are going to the offroad swapmeet tomorrow I will be there.
still live in YL and work in anaheim. Just pm me with what day. I will put it in the back of my truck. Its welded to a preset distance between mounts FYI.. But its stronger that way
I will PM you before coming down.
Thanks
Leep
Ill take those remote relay setups...will work well with a project I want to work on...
Dennis, can you grab them for me?
ROBERTK said:
I would like the mounts at the bottom of the picture. Doing a sh1tload of fab work lately. I can paypal you the $ for shipping if there's noone coming from out your way to out my way soon.
Second in line for the hatch struts. Mine just died a few days ago and i keep hitting my damn head on the hatch everytime i get anything out of the back.
will the plates for the d44 ubolts work with the 8.25?
Ill take the amp if its a 2channel for the new Pionner speaker's going into the rear hatch.
xtimmax said:
I've got a headliner in good condition. No rips, tears or sags. Was maroon and is now faded to brown.
xtimmax said:
I also have an open carrier for a 27 spline 8.25
I still have both of these. I also have a set of seats out of my 2 door. no rips or tears, maroon in cooler
I Have No idea..
2ch little legacy cheapo.
PM me if you want it
Status
