XJ99
- Newark, DE
now that I have your attention with the gangsta like lingo....
I recently swapped my tires (my BFG A/T's for his BFG M/T's) with a guy at a Merchants tire in maryland, Got home and a couple days later was doing some work and needed to take a tire off. I got out my 4 way lug wrench and couldnt get the lug to turn for anything I eventually after tryin and trying broke the 4 way Into 2 peices, now I was really pissed off. I live in delaware so I went to my NTB which is part of Merchant's tire in maryland. They said the guy doing the tire swap never torqued the lugs and my girlfriend told me she saw the guy putting my tires on and he had the air gun Just sitting on the lug putting It on tight as hell. Well they said they couldnt get them all off right then and one stud was stripped cause he put the lug on sideways. He said the lugs were so tight they pry ruined all the studs and that NTB would order new studs and Install them for free. Well I had to make an appointment took my car back to NTB and they called me 2 hrs after I dropped It off and said your studs and lugs are fine we Just had to loob them up and really work on geting them off with a good air gun.
Now thats the story I dont know If this has anything to do with that but....I never noticed this before on my XJ, I have a 4.5" Lift with 33x12.50's MT's on 15x10 ar767, Now close to everytime I go around a turn, curve, bend, my tires squeal? Is this normal? I never noticed It before. I can only be going 10-15 mph not even fast and It does It? Not sure If It has anything to do with the above story or not? I took my new lug wrench and made sure they were loose enough to get off by my lug wrench but tight enough to stay on....sorry for the long post but Is this ok?
