I have:
A Kenwood CD player with aux in on front if someone wants it.
I need:
ZJ front coils
XJ stock leafs.
Shackles and shackle mounts.
Spring perches.
Coil buckets.
Shock mounts.
Link mounts.
Stock front swaybar.
5 on 4.5 rims.
33's with some life left in them.
Any scrap metal plate or tubing for skids, bumpers and sliders.
I can pay for some of the parts if needed. I figure a I will probably wind up buying a lot of these retail, but figured the Karma thread would be worth a try, so any free parts would be GREATLY appreciated.
I'm helping a buddy get into wheeling. He has a stock '95 Pathfinder. I am giving him a D-30 with 4.56 gears and a Detroit Truetrac (I still have to install) and a Ford 8.8 with factory limited slip, disks and 4.56 gears (also have to install). He has to do this on the cheap, so we will use the ZJ front coils to lift the rear 3" and use the leafs in the front for the same (converting from IFS and a link system up front will require too much work cutting and rebuilding the header, plus added expense).
He'll also have the H233 rear axle out of the Nissan, although I doubt it will work for anyone on
. It has 31-spline shafts and almost a 9-inch ring gear, so it should be comparable to D-44 strength. The downs are that it has funky 4.63 gears and a 6 on 5.5 bolt pattern. I am planning on selling/trading it to get parts, and if someone has some of this stuff and needs the axle, let me know.
Thanks guys!
