Short arm fabrication?
The length you need will be the amount necessary to bring the castor back into spec (6 - 8 degrees). Setup the axle at ride height undet the jeep. With an anglefinder and a tape measure you'll have the measurement you need in no time.
Find the length you need to make the caster correct and make adjustable arms to give you an inch's worth of adjustability, from the original measurement.
At least 1.75" x .120. Anything less will eventually bend.
