JohnX
Sarge
- Williams AZ
Stock front drive shaft. From a 97 with aw4/231. Bad condition, needs rebuilding. Makes a clicking noise when in 4x4. $25
Speedo and gauge cluster from a 97 with 117,030 miles....get rid of those idiot lights. $50
Used mako offroad motor mounts....just like "bomb proof" design. Poly mounts, give a little vibration, so I went back to stockers before selling the Jeep. $50 for the pair.
New napa fuel pump for a 97 4.0 (kept as a spare). # P74186 Napa is $130, sell it for $80
New Napa Coil for a 97. #IC41SB New was $25, selling for $15
98 4.0 HO intake manifold. $40
MTX thunder 2160 Amp. Good working conditon, but I no longer need it. 320 watts RMS bridged at 4 ohms at .1% THD 20-20,000 Hz 425 watts dynamic at 14.4 volts. High inputs, low inputs, level adjustments, and crossovers built in. $80
Cargo Area storage drawers. Built hastily by me....not really pretty, but work very well. I used 100lbs roller bearing slides that extend all the way out so you can reach the back of the drawer. There is about a 3 inch space under the drawers for additional storage. I also left the front side open, so you can access that area from behind the back seat.
$80 in parts....labor for free.
All Red letter names will get a discount from the listed price.
