BRIANHO13
<- Yum Chocolate
- Spring, TX
These will allow you to run a better shackle angle, which will improve your off road capability as well as your on road ride.
These will allow you to lower your upper mounting position by 3 inches (lift would be around 1.5" if you maintain a vertical shackle), and move it forward up to 5". If you want to run longer spring you can simply flip the the shackle bracket.
More pictures can be seen here, http://www.naxja.org/forum/showthread.php?t=955999
If you would like to buy a set they will be $145 to your door for what is shown plus an extra shackle bolt and the two washers and nuts to hold the two pieces together. We are still sourcing the frame inserts, once we find those we will offer them as well (separatly).
Please contact myself or Dirk Pitt (Adam Dowling) for purchasing info.
