robsjeepxj
- North Jersey
I have the JCR OTK w/ JKS OTA track bar. I cut off the bushing/axle end, shortened and rewelded the rod back on. Looks like it was made that way and works great. I also had horrible scary DW, I found too much caster, bad CA bushings, kinda/not really bad ball joints(I changed from UTK to OTK to try help solve the problem so I changed them while it was apart), and a loose pitman arm. Not all at once but almost one more thing per trail ride. If you have flex joints on you control arm they will/do need frequent tightening. OH yeah and your missing a grease fitting on your lower drag link in your pics, no good either.
Even if you think something is good since it's not that old,check it anyway, check EVERYTHING, having someone shake the steering wheel while you look underneath with a flashlight(so you can see really good) helped alot.
