srmitchell
- Mckinleyville (Humboldt) CA
It's a good thing to give red letters extra discount, and it makes sense. The amount you saved goes well toward a membership!
I already have the Rough Country 4.5 full system with spring packs. I also run Tera flex 1 inch coil spacer and shackles out back. I have the adjustable track bar, braided lines etc. Full kit. Can I buy just the components need to make the front a "long arm" set up?
Yes you can upgrade to long arms, price are on the website.
http://www.roughcountry.com/jeep_xj_689U.html
Jason,
From the way the install directions read, it sounds like the bushings in the lca's at the axle are rubber since they don't say to grease them...True?
Rob
yea they are rubber.Thanks to a PM from Jason himself, the LCA axle end bushings are RUBBER! Thanks Jason!
These just keep getting better and better!:thumbup:
It looks exactly the same as the RC one. Not sure how you could say the RE kit looks like it is a stronger mounting scheme.....?
