Rockkrawler Lift?
fom_ska
Arnold, MO
from a friend - I have a 98 XJ and want a little feed back on the 6.5" Rockkrawler X-Factor lift kit. If anyone has used one of these, let me know how it does. I have an everyday driver that I take off-roading sometimes. If anyone could help that would be great. Thanks
no currently they are calling there heavy duty kits, the X-Factor kits
If you look at the 4.5 cherokee suspension kits you'll see. They have 4.5 short arm flex. 4.5 short arm something and then their long arm kit is called x-factor i do believe.
Also if you look at the tj kits, the x-factor kits comes with the belly skid if i remember correctly.
It just means its one step below their comp systems.
Like everyone has said, theres been quite a few discussions on RK products.
if you do a search under my name, chances are you'll find a lot
Matt
