R
rangerjoe2001
Guest
sorry.. i didnt know it was against the rules
rangerjoe2001 said:sorry.. i didnt know it was against the rules
91 Jeep Project said:It's allowed, but don't just type bump. Instead, actually add to your question, or type "Anyone else." Oh, and don't tell Billy......
nhrocker said:Yeah, thats the one.
I had another idea. What if instead of completely removing that corner, you bent it down so it would be flush with the side of the LA mount. Then drill and tap the side of the LA mount to accept a bolt through the front hole on the bent section of the member mount? That would give you those two bolts back. Since the LA mount is pretty stout and welded to the frame, that should work if you wanted to take the time to get those two bolts back.
