Looking for some rocker panel pretection as well as a stiffener, can anyone tell me if aj's rockrail (3/16") is what I'm after?also, will it handle a high lift? Thanks!
search for the 'rocker replacement', cut the rocker off, replace with square stock 2x4, 2x6, 3x5 whatever you like, when attached to the pinch seam and the body it will be pretty strong. tie it into the frame rails... even better.
