Rock rail questions
willysnut
Newnan, Ga.
Anybody have any pics of the self tapper type bolts to attach the rail bracket to the frame? I don't want to use thru bolts. I want to find them locally. What size are recommended? I'm building my rails just need some help with the hardware.
The thread cutters look like any other bolt, except that they have a notch or grooves cut in the end. Where are you? I get mine, in the 3/8" flavor, at Hi Strength Bolt in Denver.
Check and see if you have a fastenal in the area. Their website is www.fastenal.com If you ask for self-tappers, they will tell you they're not available 'cause they're thinking of the bolts with the drill-bit like head(these types of screw/bolts don't come in anything above 1/4"). Tell them you're looking for self-threading, and that should do the trick. HTH
Ary
What you want are "TYPE F" self threading bolts
The size you want are 3/8" x 1" they use a 5/16" drill bit.
Beware they are expensive!!!!!!!!!!
hinkley
Sounds like fastenal has what I need. I only need 8 as I am bolting the back support thru the spring hanger. Thanks for the help.
