3 of my injectors on my '89 4.0 started leaking this weekend. I picked up a set of 19lb 5.0 injectors from a friend of mine who pulled them out of his Mustang to replace with bigger ones. My question is can I just replace the 3 that are leaking or should I replace all 6? I don't not what the stock ones are rated at so I'm not sure if they can be used together with the 5.0 injectors or if I have to use one or the other?
Thanks, Kevin
Thanks, Kevin
