BPB
- Battle Ground, Washington
Ok got more gas in it. One thing I forgot to add is that at this point the only exaust on it is the down pipe. But it has ran fine with out it.
So here is the full data report.
O2 4.98v
Throttle 13%
Inj (ms)6.8-9
Rpm 575-685
Map 2.1v
Map 50 kpa
Man vac 51 kpa
Baro pres 102 kpa
Measured vacume is 14 in/hg but it drops to 12 and jumps up to 16 occasionally
Measured fp is 31 psi idle and 39 when I unhook the vacume line.
Coolant is 75 degrees c
And prom b1943ffc whatever that means
I can tell you that the exaust is no lean because it smells like a stock 350 with an 1000 cfm carb on it
O2 4.98v
Throttle 13%
Inj (ms)6.8-9
Rpm 575-685
Map 2.1v
Map 50 kpa
Man vac 51 kpa
Baro pres 102 kpa
