- MilkyWay Galaxy
Looking for feedback from any one that has tried the Renix high altitude CPS at sea level and otherwise.
They advance the timing. Put it on and drive it.
That is what I needed to know, confirmation of, thanks. Not advisable since none of my rigs have a known, working, connected knock sensor to tell the ECU to retard the spark timing when it pings....
Since I cannot cite a source this tidbit is purely anecdotal: If the RENIX ECU does not detect the knock sensor, it will default to the factory preset timing.
In short, you are giving up power, efficiency, and money, every time you fuel up.
I don't think so. The High altitude CPS is fooling the eCU as to where TDC is.
Why don't they work?
Don't you have a MT2500 to view them?
