S summitlt NAXJA Forum User Location Maine Aug 15, 2005 #1 What is it supposed to be? I cant seem to fine a number. Mine idles at around 1000rpm, and im sure thats a little high. 1990 MJ, 4.0, ax-15, np231. What should I look at to ge tthe idle down?
BIGSLVRXJ NAXJA Forum User Location Des Moines, Iowa Aug 15, 2005 #2 1000 is on the high side. 800-1000 is I believe what it should be at. 750 in gear.
RTicUL8 NAXJA Forum User Location Rocky Mountain High... Colorado! Aug 15, 2005 #3 750 with a stock alternator. Some aftermarket alternators require a little higher rpm.
old_man NAXJA Forum User Location Loveland, Colorado Aug 15, 2005 #4 600-700 is normal. A high idle is normally caused by a vacuum leak. Most common point is the hardline running by the battery and going to the canister mounted behind the bumper. Right by the battery it tends to fail.
S summitlt NAXJA Forum User Location Maine Aug 16, 2005 #5 Hmm. I just messed with those lines (pulled bumper to paint it) maybe I caused it.
C carnuck NAXJA Forum User Location seattle Aug 16, 2005 #6 check the hoses out and clean the idle stepper motor.
